54Views1Replies
Author Options:
how can I vary amp settings on a welder. Lincoln 225 AC? Answered
I have a Lincoln AC 225 welder. I would like to be able to vary the amp settings between the set stops that are on the welder now. Any one know how I can do this?
Tags:Welder
iceng
4 years ago
Probably not as the selector switch has detent stops at the weld current settings
https://www.instructables.com/id/Refreshing-your-Li...
I f your work is producing undesirable welds at both settings chances are the in between setting will not help you.
To get that in between setting just add a non-inductive adjustable series resistor in line with ground lead. Adjusting and cooling the power resistor will take time and effort.
