41384Views28Replies
Author Options:
how can a batch file be run fullscreen? Answered
i need to know which settings i need to change on my computer so that any command prompt runs fullscreen...
Zyrom121
Zyrom121
2 years ago
To get rid of the scrollbar, just make a shortcut with the buffer and window size, width 80, height 35, and the window position, left 235, top 227
Zyrom121
Zyrom121
Answer 2 years ago
To make it fullscreen, just alt&enter. Boom, now you have a fully size without scrollbar. Really good for making bsod pranks
Zyrom121
Zyrom121
2 years ago
Tried alt&enter but can I get rid of the scrollbar
Cubit-GamesY
Cubit-GamesY
Answer 5 years ago
that only works on windows 95, which is 5 windows version behind...HOLY COW ARE YOU IN WINDOWS 95?!
001DeLeon
001DeLeon
Answer 4 years ago
*9.5
001DeLeon
001DeLeon
Answer 4 years ago
lol! your dumb..
PatrickM31
PatrickM31
Answer 5 years ago
i tried Alt Enter it says my computer doesnt support
Masonk12
Masonk12
Answer 5 years ago
It worked for me. I have WINDOWS 10.
EricB215
EricB215
Answer 4 years ago
Now we know. Windows 10 is really Windows 95 w/ gadgets.
Batch FileC
Batch FileC
4 years ago
VBS Easy Make It Send %{ENTER} And That Will Make It Full Screen
imurray2
imurray2
8 years ago
type "MODE CON COLS=999 LINES=999"
JeffreyB35
JeffreyB35
Answer 5 years ago
that helped me but i don,t like the top bar showing
Prof. Pickle
Prof. Pickle
8 years ago
If you are starting something from a batch file then you can type:
start /max PROGRAM
This will open it in fullscreen hopefully.
ZombieS1
ZombieS1
Answer 6 years ago
it doesnt, actually, infact, it doesn't do anything
RajdeepK3
RajdeepK3
Answer 5 years ago
yes,but mode 1000 works .
PatrickM31
PatrickM31
5 years ago
Computer Ninja54
Computer Ninja54
7 years ago
Noooo...... That makes it open a ton of windows and eventually crash.
orksecurity
orksecurity
11 years ago
You can change how you launch the command prompt window so it launches fullscreen. For example:  Rightclick on the icon, Properties, Options, Full screen.
But you can't keep folks from opening command windows in other ways, so "any command prompt" isn't something you can achieve.
Psychic Master
Psychic Master
Answer 11 years ago
i have already tried my laptop doesnt have a fullscreen option when i open properties the box is missing from the general tab...
Arbitror
Arbitror
Answer 11 years ago
I was just going to tell you a effective way of making a single file batch program that uses registry edits to make itself fullscreen, but I see you have Vista. It got taken out of Visa because it interferes with the transparent Aero theme. I will show you how later though, I'm a little busy at the moment...
will421
will421
Answer 10 years ago
BTW Is that also took out of Win7?
Psychic Master
Psychic Master
Answer 11 years ago
thanks for the relpy i believe i can wait till you get around to it, it isnt necessary right now because i am still wrighting the code for the program.
TheBatchies
TheBatchies
11 years ago
Three good methods.
1. Open the batch file. Right-click on the bar at the top, click the "Properties" on the drop-down menu, click the "Options" tab, and change it to full screen.
2. In the code, type MODE CON COLS=999 LINES=999
3. When it is running, press Alt+Enter.
Hope this helped!
knex_mepalm
knex_mepalm
11 years ago
 You can change it in the options and I would liek to know is there a code to make it vertically go to top without opening 35 windows, I would like to make a TaT that is all.
Arbitror
Arbitror
11 years ago
Press Alt+Enter while the window is running, only works in XP...
Zengineer1618
Zengineer1618
11 years ago
Perhaps there's a command shell  alternative out there on the internet.
I personally haven't tried any of them.
Zengineer1618
Zengineer1618
11 years ago
Right click on the batch file and create a shortcut to the batch file.
Then right click on the shortcut, and go to properties.
Click on the options tab and then select full screen under display options.
Note:  ALT   ENTER  keys toggle the  command prompt screen from
            full screen to normal  and from normal to full screen.
Psychic Master
Psychic Master
Answer 11 years ago
i have already tried that it doesnt seem to work on my laptop...
