5698Views27Replies
Author Options:
how can i bend a fork like this? Answered
http://pinterest.com/pin/67835538110151033/ my mom wants a bracelet like this any ideas on how to make it?
StrangeDucks
StrangeDucks
Best Answer 7 years ago
You don't need to use a sterling silver fork... Silver plate works well and is easily available in thrift stores pretty often. If you find them, buy a couple... you might not like your first attempt or two, and they are usually less than $1. (Take a magnet with you. If it's magnetic, it's stainless steel.. if it's not, it's probably silver plate.. or silver.. which is a rare find in a thrift store... or plastic, but I trust you could divine that without the magnet! :)
Use a good pair of big, pointy pliers and clamp the fork into a vice (by the bottom, with the tines pointing up) If the pliers have teeth, put a piece of microfiber or other cloth over the jaws. The fork tines should bend pretty easily with enough force. To round it, into bracelet shape, you can use a mallet to form it around a round piece of wood.
Good luck!
steveastrouk
steveastrouk
7 years ago
Is that really a standard stainless steel fork, or is it actually silver ?
iceng
iceng
Answer 7 years ago
Spencer used a stainless steel fork..
nerd7473
nerd7473
Answer 7 years ago
since silver is expensive for a guy with no money i will stick to stainless
iceng
iceng
Answer 7 years ago
Good choice, Stainless does not work-harden !
nerd7473
nerd7473
Answer 7 years ago
ok then where can I get a silver fork on the cheap?
nerd7473
nerd7473
Answer 7 years ago
ok I thought it was a little high...
steveastrouk
steveastrouk
Answer 7 years ago
You could probably do it for around 20 bucks, if you were careful with materials.
nerd7473
nerd7473
Answer 7 years ago
thanks for the info
iceng
iceng
Answer 7 years ago
Not work-hardening is a Big Plus for steel..
Silver is a metal that as you flex and bend it will progressively harden.
That means the metal will crack and break as you try to bend and
reshape the thongs which is a bad feature for your desired pretzel.
A.
steveastrouk
steveastrouk
Answer 7 years ago
....so you anneal it periodically.....
iceng
iceng
Answer 7 years ago
That would work.
nerd7473
nerd7473
Answer 7 years ago
what should I use then confused
steveastrouk
steveastrouk
Answer 7 years ago
???Stainless steels work harden significantly, but that depends on the grade.
nerd7473
nerd7473
Answer 7 years ago
no idea
rickharris
rickharris
7 years ago
generally try to find a silver fork. Use round pliers and a bangle mandrel to bend.
http://www.youtube.com/results?search_query=cutlery+jewellery
Josehf Murchison
Josehf Murchison
7 years ago
Prison jewelry most likely real silver.
Believe it or not you just bend it into shape and polish.
I have seen spoons hammered into skull rings.
iceng
iceng
7 years ago
Start with a good fork :-)
nerd7473
nerd7473
Answer 7 years ago
now I have thanks to this link
nerd7473
nerd7473
Answer 7 years ago
no I havn't
kelseymh
kelseymh
7 years ago
There is no fork.
nerd7473
nerd7473
Answer 7 years ago
lol
mpilchfamily
mpilchfamily
7 years ago
Good bit of heat and silicon tipped pliers.
oldmicah
oldmicah
Answer 7 years ago
Totally agree on the pliers. It's very easy to put tool marks in, and very hard to get them out. I've also gone the rout of wrapping pliers In a bit of leather. Be doubly careful if you start with silver.
mrmerino
mrmerino
7 years ago
Holy cow. Uh, heat and patience.
