3239Views5Replies
how can i build a trickle charger?
I want to build a solar powered battery charger so i need to know how to build a trickle charger i can hook the solar panel up to
11 years ago
not really interested. huh.
11 years ago
I have a very simple tricle charger that works off a power supply. uses a relay and a diode and a resistor And works very well without the overheating problem. cannot over charge the batt., And has a power tap for powering a shortwave radio. Interested? Private Message Me.
12 years ago
diode to as high current as you can (atleast 5 A)
resistor : R ohm = (volts of panel - volts of battery - 0.7) / amps of diode
for example 12 V battery / 16 V panel / 5 A diode
R = (16 - 12 - 0.7) / 5 = 3.3 / 5 = about 0.6 ohm
a 24 V 40 W or 12 V 20 W lightbulb is appropriate resistor in the example
now just connect all in series with the diode pointing from the solar panel to the battery
Answer 12 years ago
I'm sorry, I don't know much about this...could you be a little more descriptive????
12 years ago
OR, if you are feeling more technical, get a pic chip or other transistor made for trickle charging (less than $5) and use the above procedure for plotting the rest of your design. This will allow the battery to charge at one rate, and trickle at a significantly reduced rate. This can also manage temperature, etc.
