2648Views16Replies
Author Options:
how can i concentrate of a bulb light at a point ? Answered
I have a bulb ( pic is attached )
and for some experimental work i have to concentrate its all light at a single point. can anyone help me that how can i do that ??
-max-
-max-
6 years ago
You will need a small point-source of like. Have you looked into carbon arc lamps, They are very difficult to make work efficiently and tweak, and maintain, but they may suit your purpose. They can make VERY small points of light that is very easy to focus into an almost laser-like beam.
If you insist on using a light bulb, do you need the 40W the one pictured gives off? Will you be OK with using a small xenon lamp or halogen lamp instead? the filaments are smaller, more condensed, and give off more intense light. I would have recomended an HID lamp but you sayed you need a blackbody radiation, so that may not suit your needs.
Kiteman
Kiteman
6 years ago
If you need a bright light at a point, you'd be a lot better off using a much smaller light-source, such as a superbright LED.
m_uamir72001
m_uamir72001
Answer 6 years ago
No, i need bulb light because of my project requirement.
Kiteman
Kiteman
Answer 6 years ago
Why? What is the project?
steveastrouk
steveastrouk
Answer 6 years ago
Something spectroscopic ? Something needing a blackbody emitter spectrum ?
Kiteman
Kiteman
Answer 6 years ago
Surely that would need a slit, not a point?
steveastrouk
steveastrouk
Answer 6 years ago
You might want to condense the light before it hits the slit ?
Kiteman
Kiteman
Answer 6 years ago
Maybe...
iceng
iceng
6 years ago
Put the filament in line with the optical axis
petercd
petercd
6 years ago
As far as I know, you cant do it because the light source of your bulb is a long coiled filament.
You'd have to start with a single point light source, much like a led or laser.
A well known example is the sun, which can be focused with a magnifying glass, if you try focusing a light bulb with a magnifying glass you just get a small sharp image of the filament.
steveastrouk
steveastrouk
Answer 6 years ago
That's why you use a condenser lens system.
petercd
petercd
Answer 6 years ago
Condenser lenses work well on a small single point of light, typical examples use a filament size of 4mm, the long tungsten filament is going to create a lot of unsatisfactory lens flare if it even works at all.
steveastrouk
steveastrouk
Answer 6 years ago
A lot depends on the size of the lenses relative to the source. In fact, you can get quite nice results even with extended sources.
We don't actually know what the OP is trying to DO with this source either.....
steveastrouk
steveastrouk
6 years ago
The optical system you want is called a condenser lens.
Vyger
Vyger
6 years ago
A mirrored box (not necessarily a cube, but with multiple reflective surfaves all pointing to a common point.) with a Fresnel lens that has an adjustable focal length. No matter what you do you will not be able to concentrate ALL of the light. Most of it will be converted to heat even with mirrored surfaces. And the lens will also absorb the light and convert it to heat.
