thanku so much for the suggestions...its a ceramic plate...i want to make a hole in it t connect a clock piece...i hav an electric drill...do u think it will work?..or will the plate break?
I have a friend named Ryu and he specializes in given hadoukens which puts holes in most material. Then tend to be large so it might not fit your application
5 years ago
You need to get a special tile drill bit and follow Rick and Kiteman's advice.
GO SLOWLY even pressure at lower speed.
5 years ago
5 years ago
A step drill is best for putting holes in thin materials. They tend to leave rounder holes than your typical twist drill.
5 years ago
Tile drill - assuming a ceramic plate.
Answer 5 years ago
+1
Also, stick a patch of masking tape over the point where you want the hole, to stop the drill-bit wandering.
5 years ago
You can use a saw or a knife
5 years ago
5 years ago
What shaped hole?
material
Size
Try going to local hardware store and asking.
5 years ago
A drill.
If you want more info then we need more info.
5 years ago
I know e monk that throws a sewing needle through a plate glass window.
Is that the kind of hole you want to make ?
5 years ago
It never ends....
Why is noone posting those informations necessary to even get a clue about the problem.
Answer is simple: Use a drill!
5 years ago
Glass plate? ceramic plate? or a plate of steel?
First 2 Id use a glass bit (spear point ) or a diamond core bit for 6mm dia holes and bigger.
Metal plate Id recommend a HSS bit (high speed steel) as is common practise on Google.
