886Views13Replies
Author Options:
how can i make a wireless switch to on of a dc motor.......i don't want any readymade remote ....can anyone help me out? Answered
i know how radio and wireless technology works .....but i m lil.perplexed about the circuitry ....so plzzz answer the ques with reasoning and diagram with appropriate values of the components needed...[.just for the the reader knowledge i m new at wireless]
Re-design
Re-design
10 years ago
Does it have to be radio?  I have a great schematic that works with an IR light.
If it does have to be radio, do you want AM or FM?
CW or PCM?
Single or multichannel?
NO or NC?
Momentary or continuous?
What voltage and current does the motor use?
RavingMadStudios
RavingMadStudios
Answer 10 years ago
And also: What do you need the switch to do that requires building from scratch instead of using/hacking an existing device?
Re-design
Re-design
Answer 10 years ago
Isn't it cheaper to build everything yourself?
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Good point. Now, if you'll excuse me I have to go finish building my giant plasma TV. I'm almost finished synthesizing the plastic for the case, and I only have two more mounting screws to chisel out of rod stock.
Re-design
Re-design
Answer 10 years ago
Are you using hydrogen for the plasma? How many volts?
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Yes, but I had to electrolyze the hydrogen from collected rainwater. I'm not sure how many volts, because I'm not quite done scratchbuilding a voltmeter yet. I'm estimating somewhere between 5 and 500 K.
Re-design
Re-design
Answer 10 years ago
Are you making your own magnet wire out of old pennies?
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Yup. The hard part is drawing the pennies through the die with my teeth,
steveastrouk
steveastrouk
Answer 10 years ago
There's an article in the new Make magazine about doing a "stone age telegraph" which would appreciate your philosophy ;-) Steve
Re-design
Re-design
Answer 10 years ago
If you built a continuous rotation servo, you could use that to wind up your wire and maybe wind your coils. You could probably use the motor from and a/c fan.
lemonie
lemonie
Answer 10 years ago
This depends upon some extent to whether you cost your labour or not.
L
arihant
arihant
Answer 10 years ago
voltage=5v-9v.....and current idk..... i want to make a am single channel remote that just on/off my motor:)
Re-design
Re-design
Answer 10 years ago
So you want it to lock on or be on only when the transmitter is on?
