58459Views14Replies
Author Options:
how can i melt a hole in a glass bottle without breaking it? Answered
i hawe a few normal drill bits and a propane/mapp gas torch.
blackiytos
blackiytos
8 months ago
i recommend just buying a bit for it, i screwed around for years of broken bottles until i just stopped whining and got myself a glass
Tutuapp
9AppsShowbox
turbonegro
turbonegro
8 months ago
A glass drill under running water works great if you want to make a hole.
I have used it on my terrariums and that glass is not especially sturdy.
But no problems.
killerjackalope
killerjackalope
12 years ago
A jet torch will easily get a bottle to malleable temperatures, poking it through once it's soft would probably be the best way to make the hole. slowly let it cool by heating it less and less or it'll shatter while cooling down....
johnfcolletti
johnfcolletti
Reply 8 months ago
What are you going to poke it with?
Melting glass sticks to every kind of metal except titanium.
Best thing is to get a glass hole saw. Like a drill bit only better for making holes in glass.
Just do your drilling in a sink so that you can have water running over the area your drilling to keep it from getting hot and shattering. You can also put a piece of wet paper towel in the hole saw to keep it cool.
Drill a perfect whole in seconds.
ManitoulinC
ManitoulinC
2 years ago
Can you not be able to heat glass without the mapp gas
weaponscollector94
weaponscollector94
10 years ago
trying to make a bong? i recommend just buying a bit for it, i screwed around for years of broken bottles until i just stopped whining and got myself a glass bit for like $10 but you could probably get one at Harbor Freight for less than that.
leigh1971
leigh1971
12 years ago
try wraping insulation tape arund the area you want to drill. then get a lubricant like butter and smother the drill bit with the butter( a tungsten carbide tipped bit will be needed) and comence drilling through the tape slowly and with light pressure. keep adding lubrication and with some time you will have penertrated the glass.
iPodGuy
iPodGuy
12 years ago
Buy a glass drill bit. Then you can make bongs for your friends too.
Swishercutter
Swishercutter
Answer 12 years ago
Agreed, then when it breaks it just cracks instead of exploding like the glass bottle my friend put a propane torch to. Plus torch temperature required depends on the glass type and temper does it not? (i.e. Oxypropane instead of just propane for hard glass)
iPodGuy
iPodGuy
Answer 12 years ago
I would assume so. I once needed to drill a hole near the bottom of a glass vase and I used a bit. The trick is to go slow (like barely touch the trigger) and to not put a lot of pressure on the bit or else the sharp edges of the bit will get snagged up on the glass and crack it. Then, you can use a torch quickly to melt the sharp edges. At least, that's how I'd do it.
Moonrabbit
Moonrabbit
12 years ago
If you can bring the entire bottle to a high temperature before focusing more heat in one spot, it might do the trick. Though you might need to put something through it. At those temperatures, the whole bottle might lose integrity and collapse under it's own weight. Otherwise yeah I'd say go for a diamond grinding bit. You might want to fill it and hold it underwater to reduce vibration and heat, just go slowly.
BeanGolem
BeanGolem
12 years ago
You could probably get the desired effect with the propane torch, depending on the size of the flame. I've seen a guy turn a beer bottle into a goose sculpture with a tiny little chef's torch and a pair of pliers. To avoid cracking, you really just need to avoid thermal gradients/shock and vibration. Have you experimented with your torch yet?
