96Views2Replies
Author Options:
how can i mod my xbox (not 360) controller to shoot really fast in Halo(without chips or soldering)? Answered
i dont got any of those fancy microcontrollers, and i dont have the slightest clue how to solder...
Tags:xbox
deadaccount
deadaccount
11 years ago
somewhere there is one instructable that only has to have you take the back off and stretch out a spring. ill try to find it again and edit this.
P.S. no smildering of micro things, just stretching a spring so it is longer.
orksecurity
orksecurity
11 years ago
Rig up some sort of switch which can be rapidly closed and opened by turning a crank, gatling-gun style?
Set up the switch with a loose contact, so that when the fire button is pressed shaking it will rapidly make and break the circuit?
If you aren't going to go with electronics, it's gonna have to be mostly mechanical. And even then you're likely to have to do _some_ soldering.
Good luck...
