128Views5Replies
how can i set speeds with a potentiometer?
Hi there, Im busy building a metronome to fit a machine im altering, (the board was totally fried and rusted through) which also has a 6volt motor that spins in the front. I managed to find a potentiometer to control the speed of the motor and the metronome, but need to have set speeds on both of them. Is there anything that i can adapt to the potentiometers like a ratchet type system ? something maybe similar to a rotary switch that u click up and down? Im pretty new to all this, any help would be greatly appreciated. MGF
Best Answer 9 years ago
Just get a rotary switch.
If you get a 2Pole 11Throw switch,
you can make an 11 position or less stop pot
using the fixed resistors for your desired speeds.
Or a single pole (lower cost ) more complex resistor math. . . A
9 years ago
A pot is a lousy way to directly control the speed of a DC motor. MUCH better to use an adjustable voltage regulator.
Steve
Answer 9 years ago
Much better to use PWM!
Answer 9 years ago
Actually, not necessarily, particularly at very low speeds. Linear supplies are usually better then.
9 years ago
If you google "set speeds with potentiometer" the first link is to a pdf document that might be what you're looking for. I didn't read through the whole document, but there is detailed discussion on how to calculate and set the variable speed.
