Test it with a multimeter where you have it connected to the controller's circuit board. When you push the button, the reading on the multimeter should change from "open" or a high resistance, to shorted (close to zero ohms).
If it does that, you should be safe to plug it in and try it out.
If it's shorted all the time, then you have trouble. Fix it before plugging it in!
11 years ago
Do you know how it is meant to work?
When you use it as it is meant to be used, does it work?
L
Answer 11 years ago
I was going to say exactly that, but thought"naw, that's too obvious". It is the best way though.
Answer 11 years ago
Funny, I saw the question and thought to post the same answer.
+1 for Lemonie
11 years ago
Answer 11 years ago
...just don't take it online - they can detect the led-to-trigger-jumper trick and you will get your system and gamertag banned :(
