14156Views4Replies
Author Options:
how can i tell where the ground is on a pcb? Answered
modifying antenna on a radio need to make sure it is grounded to the board. How can I tell where the old antenna was grounded?
Schmidtn
Schmidtn
10 years ago
Depends on the type of circuit, AC or DC.
DC's - easy... ground will flow to the negative end of your power source (battery pack)  Find where your batteries go into your circuit and find the negative hook up (normally a black wire).  That's your ground.
AC - could be trickier.  It's harder to tell neutral from ground... three prong outlets have a: "hot," "neutral" and "ground" plug.  Electricity flows through your product from hot to neutral.  The ground is a safety feature.  So manufacturers ground out their products so that if a hot connection comes in contact with whatever their product is housed in it wont kill somebody.  Instead, it'll connect to the ground, throw your breaker/fuse and cause your product to quit working BUT it also wont kill you!  So I'm not sure if you're looking for neutral or ground.  Ground will be physically connected to whatever your product is housed in.  Neutral will be on the circuit board and normally has a thicker trace than other traces on the circuit board.  Also (as frollard mentioned) all components with polarity will have their negative leads attach to this trace.  The none striped side of diodes, the striped side of electrolytic capacitors, etc.
camb00
camb00
11 years ago
There should bee a large amount of solder on a component those are normally grounded
notmyfault
notmyfault
11 years ago
A lot of times the mounting screws will be grounded (if your radio has mounting screws to hold the pcbs) Also some heatsinks will be grounded. NOT all, some can be tied to collector voltage. Look real good with a loupe ( magnifying glass) sometimes you can see where it used to be hooked up. NMF
