36414Views26Replies
Author Options:
how can u tell how old a mirror is? Answered
Tags:mirror
catharris33
catharris33
3 months ago
Trying to figure out my hand held mirrors age can you help me?
15978785018222285176966907948396.jpg15978785533081628236576486044323.jpg15978785862602617416643837971237.jpg
triggers2less
triggers2less
3 months ago
The date you bought it will be on the receipt
luvit
luvit
10 years ago
hold the mirror 16 inches from the ground with the shiny side up. drop it flat. count the pieces it separated into and multiply that number by 0.12. that's how old the mirror is.
triggers2less
triggers2less
Reply 3 months ago
Thank you! I came up with 48 years! Anyone want to buy 400 kinda small but really old mirrors?
MargieP17
MargieP17
11 months ago
Can you please look at my mirror?
triggers2less
triggers2less
Reply 3 months ago
Must be broken. That’s not my carpet!
Tawnni
Tawnni
10 years ago
So, my friend told me that you can tell a mirror's age by holding a lighter close to the mirror, and count how many flames you can see in the reflection. You need to look at it from an angle. Then multiply the number of flames by 7. Does any one know about this? Or ever hear about it? My friend wasn't certain on the number of years and I wanted to know the truth. We tested all of the mirrors in the house, all were different. Any thoughts?
Greg Monroe
Greg Monroe
Reply 2 years ago
I was told to use a candle but a lighter works as well. I was also told that each reflection of the flame represents 10 years of age. Why or how a mirror does this and why a single flame works I do not know but sure would like to.
phildough2
phildough2
Reply 9 months ago
Gravity... old glass will eventually sag. Creating wave like lines.. my guess
Michael cobal
Michael cobal
Answer 2 years ago
In the late 70s I worked for for an elderly woman . antiques dealer she told be something similar which was 10 years for every reflection where she heard it from I don't know but that's all I know
castillojorge17
castillojorge17
10 months ago
Have old mirror , fair condition and heavy 31x50 what could it be worth
PatriciaD129
PatriciaD129
11 months ago
Can anyone tell me about this antique mirror and looking at the back I can tell it is old and there was a small nails at the back of it?
amber.d.shelley
amber.d.shelley
1 year ago
https://imgur.com/a/zxynyYc Here are more pictures of the mirror. The wood is hand sawed and the wooden backing has shrunken over time. The glass is not beveled, and is the same thickness throughout. Not plate glass: the surface is quite uneven, and a very distorted reflection is given with a yellow hue. Many air bubbles in the glass, and it looks sorta sparkly up close. No spiral affect. There is some oxidation to the metal. Any idea of how old it is?
PrestonL9
PrestonL9
2 years ago
want to figure out what kind of stone is in the back
PrestonL9
PrestonL9
2 years ago
want to figure out how old a mirror is by putting a flame in front of it
RayW60
RayW60
2 years ago
Mirrows:Can any tell me what this is and maybe how old.
DebbieS96
DebbieS96
4 years ago
Can anyone tell me about this hand mirror?
MarkH162
MarkH162
4 years ago
any ideas on this one ? The mirror has alot of sparkles in it. I know it goes back to at least 1900
psheathercronk
psheathercronk
6 years ago
yes I have heard of putting the lighter up to the mirror but as far as it being true as to the age of it , honey I don't know, I'm claiming it because it's what I've always done, OWCH , change is scary
jtobako
jtobako
10 years ago
Start with the glass-antique glass isn't flat, it usually has ripples and/or bubbles in it, as well as more color (greens, browns and blues depending on chemical traces and length of time exposed to UV light).  True silver backing will usually show light spots and clear areas, sometimes turning black or flaking off (but so will more modern backings).
seandogue
seandogue
10 years ago
A chemical test on the reflective material may indicate the age of the mirror, since I *think the material used was changed somewhere during the 19th or early 20th century.
Also, modern mirrors are made using glass sheet that has almost no imperfections (bubbles for instance). Bubble in the glass, even small ones would indicate some age.
lemonie
lemonie
10 years ago
Historically mirrors had bevelled edges, reflective glass without being a "looking-glass". Since grinding & polishing glass is time-consuming & expensive, if it's got the edge (and a wooden frame) that's an indication of some age.
Why?
L
RavingMadStudios
RavingMadStudios
10 years ago
The only trick I know is to place the point of a pencil on the glass and see how far away the reflection appears. Older mirror glass is thinner, so the closer the reflected point is to the real point, the older the mirror. If it's a wall mirror, check the glass thickness at the top, middle and bottom. If it's noticeably thicker at the bottom, that is also an indicator of age. Older glass will also tend to be a bit wavy.
None of this will tell you how old the mirror is, though. For that you need an antiques expert to actually examine the mirror.
Willard2.0
Willard2.0
10 years ago
Check if there is a production date on the frame, back or in a corner.  I would think that an old mirror would have a little flaking of the reflective coating around the edges.  That's all that I can think of.
Willard
