254Views4Replies
Author Options:
how do i change a bike into a man powered generator? Answered
i want to take a bicycle or an excercise bike an convert it into a man powered generator, to be used to charge batteries in the event of long term power outage.
scitekman
8 years ago
The best way to convert an ordinary 26" bike into a human powered/electricity bike is simple. You will need to make a frame to support the rear wheel off the ground, then you need to remove the rear tyre from the wheel. The wheel will become the pulley. You will need a 24 volt x 100 watt electric scooter motor and attached it to frame, make a small, or buy a pulley to run a belt from the wheel to the motor. Electric scooter motors are excellent as dc generators, and will charge batteries and even run and inverter.
sonicsworld
10 years ago
If your using a bike dynamo they put out up to 90 volts a.c.. you need a rectifer to convert to d.c. and a regulator to control the voltage. But a lot of the new bike dynamo's should be regulated. This is the easiest way of doing things.
Steamdnt
10 years ago
You could use a dc motor from an auto parts store, if you used the alternator froma car that might work.
