73Views4Replies
Author Options:
how do i code a pattern of leds on a attiny 85? Answered
I am making a prop and i need to embed a attiny to run 3 leds in a specific pattern, here is the patterm
led 2 on for .75 seconds
led 3 on for .75 seconds
that pattern repeated 3 times then
led 1 on for a half a seconds
then 2 on for 1/2
then 3 on for 1/2
that repeated twice then the whole thing restarted
i dont so much want some code i want to learn how to do it please help
rickharris
rickharris
4 years ago
YEs? No? like? Don't like?
not the answer you wanted?
You haven't been back to read it/?
hello out there :-)
just appreciate some feed back to keep me answering questions here>
iceng
iceng
Answer 4 years ago
15 yr old kids don't have social skills or empathy.
BTW your basic program is sooo much easier then the equivalent c code.
rickharris
rickharris
Answer 4 years ago
:-) I got carried away, just needed some kind of feedback so I know I am not talking to myself!
Picaxe is a very powerful system and MUCH MUCH easier to use than Arduino IMHO 14 microprocessors from 8 pin up to 40 pin and over 250 commands available.- Not so fast in operation as some though, however for many projects that isn't an issue.
Cheap too.
rickharris
rickharris
4 years ago
https://www.sparkfun.com/products/10803
For something this simple you can best use an easy to program micro processor. Available from Sparkfun for $2.95 this should fit your needs.
The diagram shows 3 LEDs connected - The 470 ohm resistor can be smaller if you need brighter LEDs - 470 give you about 10 mA 330 give you about 15 mA the max is 20 Ma per output.
The program is very easy - the manuals (see link below) will tell you all about how to do this and what you need 9a cheap cable to connect and i would suggest a small bread board the the picaxe bread board programming jack.
Prog:
start:
for b1= 1 to 3
high 2
pause 750
low 2
high 4
pause 750
low 4
next b1
for b1=1 to 2
high 1
pause 500
low 1
high 2
pause 500
low 2
high 3
pause 500
low 4
next b1
goto start
that's all you need!
I assumed you want the LED's turned OFF after the time - you don't actually say.
If you need this explained Pm me or ask here
http://www.picaxe.com/Getting-Started/PICAXE-Manua...
