6497Views2Replies
Author Options:
how do i conect a 6v relay ? Answered
(the 5 connections relay)
Tags:relay
orksecurity
Best Answer 9 years ago
Of the five connections:
Two are to the coil. They're interchangable. Apply and remove power across these to switch the output.
One is output common. One is output normally-closed. One is output normally-open. When power is not applied to the coil, common is connected to normally-closed. When power is applied, common is connected to normally-open.
As far as which pin is which: The relay may have come with a small diagram labelling the pins, or the may be labels on the relay itself (often just a letter or two -- NC, NO, and so on), If not, you can figure it out with a bit of experimentation... or, if the case is transparent, you can often figure it out by inspection.
lemonie
10 years ago
For what purpose? L
