381Views12Replies
how do i even out my dual gearbox?
i have a tamiya dual gearbox hooked up to a tamiya tank base. i found the one side's track goes faster that the other.. how can i fix that? i tried reversing polarity but the same side goes faster... i have the motors hooked up in series.. thanks!
8 years ago
Put an encoder on both output shaft. Monitor the difference and balance them.
10 years ago
Don't hook-up in series and what happens?
L
Answer 10 years ago
is there anyway i can use this circuit without hooking them up in series?
Answer 10 years ago
Parallel-wiring. But that's what Burf said and you already gave him the best answer.
L
Answer 10 years ago
i just did that because it felt like this thread was dying out. if i feel so, I will change it to the righteous (winner?). hmm, the uploader isn't working for me....
Answer 10 years ago
You connect the motors to the same power-supply, witho... like this:
L
Answer 10 years ago
heres the circuit im using...
Answer 10 years ago
Is a dual H Bridge setup a parallel connection? specifically an l298hn chip.
10 years ago
Is there any trim adjustment, like on RC planes, to even up things electronically?
Wiring them parallel should at least help.
Answer 10 years ago
I'm using my gearbox for a light seeking robot, and I don't know how to wire it up in parallel in my case...
10 years ago
It's not the gear box it's the motors that are running at different speeds.
Unless there is a mechanical issues on the slow side the gear boxes will always produce the same output for a given input.
I guess the tank is intended to have 2 motors driving separate tracks so you can alter the speed of either motor for steering. You may well be using this incorrectly.
Best Answer 10 years ago
The first thing you should do is check for axle slippage or binding on the slow side.
Then, wire the motors in a parallel circuit. That way, they will try to maintain the same speed. When one motor gets more load than the other, it will draw more power to compensate without affecting the other.
