2683Views15Replies
Author Options:
how do i fix my ibm thinkpad 600x , when i turn it on it gives error 8611 ? Answered
sometimes gives
161
163
173
301
Etc etc, ive seen wud these codes mean, read a lot of instructions, but seriously, i need a REAL solution!
steveastrouk
steveastrouk
Best Answer 9 years ago
So, if you've seen what these messages mean, what have you done to fix them ? Like reseating the keyboard cable, changing the back-up battery etc ? Have you tried to fix them ?
Steve
N.Khan
N.Khan
Answer 9 years ago
dude, ive reset the keyboard, (my mouse got flushed in the toilet) bt nowhere it sais that its a mouse problem, nyways, ive reset the keyboar, hit the motherboard wid a hammer (didnt brk it, still turns on and gives stupid error numbers) ive heated the thing wid a lighter, put it in the freezer, (in one sentence ive tryed evrything i found on net so far, and tryd some stuff my self)
All these tests and nothing,,
Wud da hell should i do, i want it fixed i really luvv it, bt nothing doin anything :/
steveastrouk
steveastrouk
Answer 9 years ago
You haven' changed the back-up battery ?
N.Khan
N.Khan
Answer 9 years ago
i really need to go to a lot of trouble to do dat, (ibm service center is pretty far) ,, but i didnt try bcoz the battery error only comes a few times, mostly its ok
steveastrouk
steveastrouk
Answer 9 years ago
I think hitting it with a hammer and attacking it with a lighter will have killed any chances of making it work properly now.
N.Khan
N.Khan
Answer 9 years ago
owwh come on!!!, it still gives the same damn error msg 8611 , and i only tried to burn off the plastic around a broken screw and when failed later on broke it with a hammer, ,,,
What do u have to say about this so called 8611 ??
AndyGadget
AndyGadget
Answer 9 years ago
See my link for a suggested fix for the 8611 code, but from the errors you're getting and the treatment you've given it since, I think you should stop wasting your time on this and get hold of something a bit more functional.
And a word of advice - laptops will work for a lot longer if you treat them with some degree of care.
Vyger
Vyger
Answer 9 years ago
So its terminal then. Sometimes things are beyond fixing, you will learn that better as you log in a few years.
7654321
7654321
9 years ago
Why on earth would you use a lighter and a hammer on your motherboard?
N.Khan
N.Khan
Answer 9 years ago
7654321
7654321
Answer 9 years ago
according to my google search, the 8611 error is a "trackpoint error, most likely in your keyboard or subcard"
Vyger
Vyger
9 years ago
Its a pretty old notebook, Pentium 2 running windows 98 from I can tell.
It might be time to upgrade. Anyway if you try Google you can find a lot. Here is one link from a support forum.
http://www.fixya.com/support/t290907-ibm_thinkpad_600x_pc_notebook_08611
And then you can go to Lenovo's list of error codes. Which is here
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=lwik-3sr4pw
From what I am reading I thinks its dying, and aspirin will not help it.
N.Khan
N.Khan
Answer 9 years ago
ive seen all of these, nothing has helped so far
AndyGadget
AndyGadget
9 years ago
The third post HERE suggests it's a trackpoint detection problem, and suggests a fix for it.
Several years ago I had a 600x where it stalled at bootup because the processor fan wasn't running.  My fix was to blow hard into the side port to spin the fan each time I booted it and that kicked it into life.
N.Khan
N.Khan
Answer 9 years ago
huh?
But the fan does spinn, mayb nt really fast, i do recken the processor getting really hot, bt the fan's not on the processor its on the motherboard, no wonder which stupid idiot put a fan on capasitors, bt were u havin the same error msg....?
