79Views3Replies
Author Options:
how do i make my LED dance suit flash?strobe? Answered
i am going to a festival next friday and i made an LED stickman suit. at the minute i can only turn the LED's on or off but i want to make them strobe at different speeds so i can match them to the beat of the music
Rajkumar2506
Rajkumar2506
4 years ago
you can use square wave oscillatorIC 555 to turn ON and OFF the LED.
IF you want to vary LED lightning Speed you can add a potentiometer in IC 555 or
you can use Pulse Width Modulation(PWM) circuits to vary lightning speed of LED
iceng
iceng
4 years ago
Try adding an audio pre-amp to the 555 input.
Then add a Darlington to drive your LEDs.
Be sure to click the picture to view the entire image..
steveastrouk
steveastrouk
4 years ago
How are you switching them on and off ? A physical switch ? You'll need a transistor that can handle the current, and probably something like a 555 timer to switch it on and off. You'll have a potentiometer to adjust the flash rate
