255Views3Replies
Author Options:
how do i replace a faucet? Answered
I have a leaking faucet and would like to replace it.
frollard
10 years ago
A leaking faucet can often be fixed by replacing the o-rings inside it. There's likely a protective cap holding the handle's retention screws secret ;) As lemonie says - turn off the water supply. Pry off any covers, unscrew and remove the handles..., then look for a large (usually brass) nut holding the valve assembly in the faucet base. Once removed, look for the rubber o-ring. It's likely compressed, or cracked. Get a new one from the store, costs 1-2 dollars. Lubricate it with some petrolium jelly for ease of installation, then reverse the steps to reassemble. I can't be more specific without seeing what type of faucet you have.
frollardfrollard
Answer 10 years ago
also works == soap to lubricate the installation, this also prevents the petrolium jelly from coming off in your water supply.
lemonie
10 years ago
You need to turn off the water supply first - make sure you can stop water coming out.
You then need to remove the handle (a screw in it somewhere usually)
Can you go that far and add a picture? (putting it back from there should be easy)
L
