49Views0Replies
Author Options:
how do i start a project using a microphone to cause a servo to "sweep" depending on the sound level? Answered
i really want to make a servo rotate like when using the sweep code but with a microphone instead of a potentiometer. the servo would move depending on the decibel level and return to it's default position once the noise stops. i can code myself but i don't know where to start and i can't understand the microphone related code parts, i could really use some help with getting started, i would be greatful on many levels.
EDIT: i scraped this together but it doesn't work exactly how i want it to
#include <Servo.h>
int micPin = 1;    // select the input pin for the mic input
      // select the pin for the LED
int micValue = 1;  // variable to store the value coming from the mic
Servo servo09;
void setup()
    servo09.attach(9);
void loop()
    micValue = analogRead(micPin);
// use what ever threshold between 0-1023 you wish to switch  the led
    if (micValue > 2)
        servo09.write(10);
        delay(1);
    else
        servo09.write(100);
        delay(1);
