1310Views5Replies
Author Options:
how do i wire surface mounted SMD RGB LEDs in series? Answered
frollard
frollard
8 years ago
It's easy to hand-solder smt parts - you just need flux, tiny solder, and a good iron.
Then you are either wiring them dead-bug style or soldering them down to a circuit designed for them. Youtube has a lot of videos on smt soldering.
iceng: There are RGB that have 3 separate anode/cathode connections if you want to do some fancy matrixing, but you are right - usually you get common cathode or anode for a 4 pin package.
iceng
iceng
Answer 8 years ago
+1
Live and learn 6 pin RGB LEDs wowee
If you come across a source link please copy me with it :)
I still want to caution 21century  about over heating the BLUE LED
pins when dead-bug style or soldering.  It would be a shame to lose
a whole LED for a touchy blue diode.   Like tonight installing a blue LED
sign for  air flow on my plasma cutter got overheated from shrink-tube
and I had to rewire  that LED a second time being carefullest heatsinkinging
the led when heating.....
A
iceng
iceng
8 years ago
You don't...
The RGB LED ( weather common anode or common cathode ) are not
arranged for series wiring because the three LEDs are connected to a
single terminal on one side.
This is true for SMD parts and through hole parts.
If you want to make a series RGB you need to use individual Red, Green
and Blue LEDs....
A
21century
21century
Answer 8 years ago
I got that but how do I solder such small connectors?
iceng
iceng
Answer 8 years ago
The same way as all other SMT parts can be soldered to a PCB.
A hot plate with solder paste is the DIY way.
I layout my smt pads with extra area to permit side solder in-flow
and use something like a princess solder iron and can do 25 mil
spacing.
A
