323Views3Replies
Author Options:
how do you determine weather or not a 20 amp plug is single phase or double phase? Answered
rich_moe
rich_moe
Best Answer 11 years ago
4 prong (neutral, 120vac ph1, 120vac ph2, and return - 2 phase plug 3 prong (neutral, 120vac, and return) - single phase 3 prong (neutral, 208vac, and return) - 2 phases tied together in a 3 prong plug. These are usually electric ranges, dryers, heavy household items, sometimes arc welders (Lincoln comes to mind) In other words, it depends.
pepsiman357
pepsiman357
Answer 11 years ago
Thanks rich_moe, I did buy a used Century arc welder (Century has been bought out by Lincoln and has no info on the welder I bought) and the plug has 3 prongs, 1 horizonal, 1 vertical and 1 ground. when I went to Lowes to buy a outlet, they had 2 kinds, 1) that said single phase with a silver screw, a brass screw and a ground screw 2) that said 2 phase with a ground screw and 2 brass screws. I'm assuming that the welder would use the outlet with 2 brass screws ( power to each prong) but I didn't want to wire the wrong outlet with out consulting someone that knew more about welders. Thanks for all the help Kris
Junk_Wizard
Junk_Wizard
11 years ago
get a voltage tester and stick it into the vertical slits, if its ~220 its double phase, if its ~120 its single...
