36254Views9Replies
Author Options:
how do you disable the speed governor (limiter) in a car? Answered
How do you disable the speed governor (limiter) in a car? No specific car just wondering the different ways, and what actually tells the limiter to kick in?
Swishercutter
Swishercutter
Best Answer 11 years ago
Depends on the car. Some you can just clip the Vehicle Speed Sensor wire (not recommended since you can't be sure what else uses that signal ex. ABS). Some you can just change out the chip which has been suggested, or with a reprogrammer. I thought about doing this on my car and in order to do it properly while ensuring that no other systems were influenced was to mimic the Veh.Spd.Sens. all the way up until right before the speed sensor enables then just repeat the signal making the ECU think that it is still going under the governed speed. Basically something that copies the frequency and duty cycle of the pulse.
KevinO144
KevinO144
Reply 2 years ago
Ok mine when I disconnect it always sense and I don't know the sensor wire
Mohd Azad khan
Mohd Azad khan
11 months ago
how to turn off speed governer for ertiga tour m cng
Kishmu
Kishmu
11 months ago
How to turned off speed controller in bolero maxitruck
SumitS147
SumitS147
1 year ago
please suggest how to switched of speed governor in my grand i 10 car
An Villain
An Villain
11 years ago
find it, RIP IT OUT, hope your car still works.
cdubnbird
cdubnbird
11 years ago
set off an emp bomb.
goodgnus
goodgnus
11 years ago
Depends on your h4x0r skills :P Most governors can be eliminated or overridden by the use of an aftermarket "speed chip". Google "car speed chip".
Sandisk1duo
Sandisk1duo
11 years ago
i would think that the governor is all electronic...
