8697Views14Replies
Author Options:
how do you fix a hole in a ram-x (polyurethane) boat? Answered
its hard to find something that will "stick". any suggestions? hole is about the size of a half dollar?
velojym
3 years ago
My old Coleman had a hole from a friend dragging it across rocks, right on the keel. I bought a rubber kitchen glove. Flexed the canoe so the aluminum keel member separated from the hull, and slid the glove in, then released it. The tube clamped the glove in well enough that the leakage was about what was coming in from the paddles, etc. That "repair" held for years, until I sold the canoe, and that friend removed the glove to attempt (unsuccessfully) to repair the hole. That was 15 years ago, and I think I'll be getting the old girl back soon.
velojymvelojym
Reply 1 year ago
Well, it took a while, but my old Coleman is back. My friend ended up using some sort of foam filler to patch the hole, and it appears to be holding so far. If it doesn't, I'll just go back to my old method. I don't know that this boat will get a lot of use, as I do have a far newer, and better, Old Town, but the old red tub has a lot of memories pooled up in it. We'll probably need it when we go paddling as a family, as the three of us are now a bit much for one canoe since my girl is growing so fast.
PeggyS61
1 year ago
Why not use A + B epoxy putty? It can be applied under water for boat repairs, so it says on the box. I'm a newbie, forgive me my ignorance.
Re-design
10 years ago
Can you get to both sides of the hole. If you can then you can use large fender washers and a bolt to clamp two pieces of rubber over the hole. Like a tinker would fix a pan with a hole in it. Might not look to pretty but you still get to fish.
charlie2dogs.baseballman2271
Answer 3 years ago
you can buy a toggle bolt, that has a foldable wing to insert into the hole put a reasonably thick rubber washer larger than the hole with a metal washer on the outside of it and tighten n place put a dab of silicone around the bolt head that meets the washer. im doing the same thing.
Re-designbaseballman2271
Answer 10 years ago
Get a couple of cans of foam in a can from. fill the void inside with the foam and let it cure. Then roughen up the outside of the surface a little. Then drill a bunch of small holes around the area that needs to be patched and apply a fiber glass patch. The fiber glass resin will stick to just about everything. and the resin will seep into the holes and lock it into place.
iselox
8 years ago
I'm trying out that G/flex right now on a similar project--will let you know how it works out.
Blue Water
10 years ago
I beleive that Ram-X is polyethylene, not polyurethene which is not a plastic. Ram-X is a low density polyethylene and thus difficult to repair. DO NOT use polyethylene from other boat manufacturers as high end boats use super-linear and crosslinked polyethylene which is a more durable product. A good clue to the quality of plastics is to see if they are re-cyclable. If they are, chances are they are repairable. Ram-X is not. I have repaired Pelican vessels with West Systems G-Flex. The Center layer of Ram-X may be polyurethane and if so, does not offer any structural integrity to the vessel and is more difficult to repair than LDP.
Sandisk1duo
10 years ago
did you try filing it with epoxy, caulk, or superglue?
Sandisk1duobaseballman2271
Answer 10 years ago
i just looke up 'polyurethane epoxy" i bet you can fill it in with that
