5978Views6Replies
Author Options:
how do you get plastic cups apart that are stuck together? Answered
Burf
Burf
11 years ago
Run hot water over the bottom cup until it is as hot as it will get, then pour cold water into the top cup and pull them apart immediately. The heat expansion of the bottom cup and the contraction of the top cup should be enough to break the seal so you can pull them apart.
NachoMahma
NachoMahma
Answer 11 years ago
.  That's what I would try first.
.  Use a little percussive force, if needed. Ie, give it a good rap on the counter.
Re-design
Re-design
11 years ago
Slightly deform (squeeze) the inside cup and pull/twist at the same time.
Acepilot42
Acepilot42
11 years ago
you gotta keep 'em seperated.
JaredsProjects
JaredsProjects
11 years ago
ummm...can you give some more description, how are the stuck together, maybe a picture?
AI
