19932Views9Replies
how do you make artificial sapphire?
im not looking for how industries do it large scale, i need to know how to make clear and/or colored artificial sapphire at home
1 year ago
https://www.youtube.com/watch?v=MLV1pPvTpIw
2 years ago
Press aluminum foil, iron and titanium together with heat and air and get a sapphire. You want a ruby? Just add chromium to the batch. ;)
6 years ago
Bem,a melhor maneira de se produzir a safira em casa é pelo processo de verneuil,que é o processo de fusão por chama,este é o modo como eu faço em minha casa,boa sorte.
8 years ago
get yourself an arc welder or similar arcing device and some carbon arc rods from a welding supply place and fill a ceramic bowl with alumina, your going to need some kind of carbon wire or high heat resistant rod with a sapphire on the tip to move up and down in the bowl.
9 years ago
Its not a home scale process, unless you reckon you can employ pressures of several thousand PSI in tanks whilst you grow quartz lumps.
You make them in a process that uses temperatures around 700 F, in pressures of 30,000 PSI, over at least many days, and sometimes months !
Steve
Answer 9 years ago
And when you're done you can look for gravitational waves!
Answer 9 years ago
Those are some big effing sapphires!
Picture copied from here:
http://www.aigo.org.au/industry.php
http://www.aigo.org.au/aigo_web_images/masses.jpg
Quote from:
http://optics.org/news/2/9/29
"Because of the incredibly high sensitivity needed to detect any such change, the interferometer mirrors must be based on very high-purity materials, and have extremely low heat absorption at the laser wavelength of 1064 nm – since any build-up of heat would cause thermal lensing and enough of an error to ruin the experiment. The sapphire provided by GT Crystal Systems has an absorption of only 40 ppm/cm at the key 1064 nm wavelength, says the company."
9 years ago
It's not going to happen for you.
If all you need is a blue stone, then clear casting resin can be coloured and give a good representation.
They are not expensive to buy.
9 years ago
Sapphire is a form of corundum, crystalline Al2O3.
http://en.wikipedia.org/wiki/Sapphire
http://en.wikipedia.org/wiki/Corundum
The wiki article on corundum points to another article titled "Verneuil process".
http://en.wikipedia.org/wiki/Verneuil_process
And, uh, that looks to be straightforward... You know, you just need clear a space in the garage, so you'll have some place to build it.
BTW if you can figure out a way to do this using a domestic microwave oven, e.g.
http://www.popsci.com/diy/article/2003-09/smelting-microwave
then that would be worth some serious mad-science geek cred, just because.
