150Views4Replies
how do you make it look like your in a pitcher booth.?
how do you make it look like you got your pitcher from a pitcher booth.? like the ones at the mall nd stuff.?
11 years ago
If you mean the automatic self-portrait machines: Sit in front of a curtain, use a fairly wide-angle lens (proper portrait lens would be 100mm, but I'm sure they're using something shorter given the limited space), shoot with flash diffused down from about 30-45 degrees dead front... Basically, go look at the booth you're trying to reproduce, and build an equivalent.
Or are you asking how to put multiple pictures on a single strip of paper? If so, almost any image editing tool can be used to build the composite image; then print it onto suitable paper using a good inkjet printer.
Or did you have some other question entirely?
11 years ago
Picture. What are you after here - change the image attached to "you":
www.instructables.com/you/settings
Or something else?
L
Answer 11 years ago
1) Hire an actor
2) Rent a baseball uniform
3) Build a booth
4) ...
5) PROFIT!!!
Answer 11 years ago
Not knowing what these things at the mall are, that gives me a better idea.
L
