76Views3Replies
Author Options:
how i can reduce output current? Answered
i have SMPS  with output ratingd 24v dc and 5A.  The other one is 12v dc motor which has max input current is 200ma with load.  How i can connect these both itoms?
-max-
-max-
5 years ago
Voltage is like electrical pressure. The more V the power supply has, the more amps it can push into a given load.
Current is like flow rate. The more I that your power supply is capable of, the more it electrons it can push around. But it will not push this current around if the V is not high enough or R is not low enough.
Resistance is exactly what it sounds like. It is how much the load resists current flow. The greater the R is, the higher the V needs to be to push the amps.
Power is basically nothing more that the product of voltage and current.
Mathematically, this is all just basic ohm's law. E = IR or with units: V= A*Ω.
seandogue
seandogue
5 years ago
V = I x R rulez all.
As Rick said, current is not pushed, it is drawn based on the load resistance (or impedance more accurately) and the source voltage.
rickharris
rickharris
5 years ago
The DC motor will only draw the current it is rated for - no need to reduce anything.
Current is not Pushed into something, it is drawn from the available supply.
