191Views4Replies
Author Options:
how many dc motors can be controlled using dtmf decoder mt8870 ? Answered
i am making a mobile controlled robot project using dtmf decoder ic
i want to control 11 motors is it  possible and how
which motor driver should i use
and can i use atmega 8 or 16
Tags:dtmf
steveastrouk
steveastrouk
6 years ago
It gives 16 tones IIRC, so you can do 11 motors. If they're small, you can use the L293.
townyw
townyw
Answer 6 years ago
how 16 the mobile keypad has only 12 keys so how to produce 16 tones
i am using 12v dc motors
so how many l293d should be used ??
steveastrouk
steveastrouk
Answer 6 years ago
The DTMF standard supports 16 codes - but you knew that by reading the data sheet didn't you? The 293 only takes motor current up to
townyw
townyw
Answer 6 years ago
I am planning to make a bot which can
move forward when 2 is pressed
backward -8
left-4
right-6
and want to control 4 more motor separately and 2 leds
i saw this layout but with this i can only control 2 motors
and where will i get code for this
