8438Views7Replies
Author Options:
how many ohms does it take to resist one volt? Answered
how many?
Tags:OHMS
rocketman221
rocketman221
12 years ago
resistance limits current not voltage.
oweng4000
oweng4000
Answer 12 years ago
But how would i remove enough current from a nine battery to make it power a 3 volt chromatic tuner?
rocketman221
rocketman221
Answer 12 years ago
How much current does it draw? you cant figure out what resistance you need without knowing how much current you need. however i think a voltage regulator would be much better for what you need. this is a good site to get them from. the LM1086CT-3 would probably work.
Plasmana
Plasmana
12 years ago
Not posable, the higher the resistance, the lower the current can pass by, but the voltage always remain the same.
RuscoSparky
RuscoSparky
12 years ago
Well were are missing one part of the equation "Current" because V = I R so if we dont know current how are going to find your answer.
purduecer
purduecer
12 years ago
That depends on the amount of current you have flowing through the object of interest. Ohm's Law provides a means to calculate voltage, current, or resistance for (most) materials.
UziMonkey
UziMonkey
12 years ago
It doesn't really work that way. The resistance is going to be different depending on what else is on the circuit and what the supply voltage is. Further, "volts" are not resisted. Resistors cause a forward voltage drop and resist current.
It sounds like you may need this.
