162Views11Replies
Author Options:
how much backup can be obtained from 18650 (2600mah) battery and 5w led bulb as a load? Answered
hello;
i have some basic questions and want to clear my mind.
i want to create a portable power bank using 2*18650 (2600mah) rechargeable battery and 5w usb plugged led bulb (5v).
So keeping in mind the above values how can i determine the maximum backup this setup can provide?
i would highly appreciate if you provide some real life examples to calculate the above mentioned values.
Downunder35m
Downunder35m
5 years ago
Use a proper battery pack or a suitable LED.
What you want is not really feasable and will not really be good for the lifespan of your battery.
If you need 5V you also need a converter that reduces the max power a little bit.
Makes me wonder why people always want to go overboard with LED's these days...
askfriends
askfriends
Answer 5 years ago
so you suggest to use 2 18650 batteries? so if i use 2 batteries how much backup will it provide for 5v led bulb?
-max-
-max-
Answer 5 years ago
LEDs have drop voltages around 3.2V or so, which is about how low you can safely discharge a lithium ion battery to! battery capacity is really a difficult thing to calculate accurately. The easiest way is to simply assume that you can derive the WH rating of the battery from the mAH or AH rating you see. Problem is though is that the voltage of the battery will change as it is discharged, and the discharge curve will depend on many, MANY factors, like the rate of discharge, the type of discharge (constant resistance, constant current, or constant power, or something more complicated?), the temperature, etc etc etc.
To calculate roughly how long your LED will be powered, you will need to first look into the LED driver you plan to use, if any. You will need to consider how much current the LED draws as a function of the voltage applied to it. Most good drivers will be roughly constant power, meaning that as the voltage applied to the driver sags, the current that it pulls will increase, such that the product of the voltage and current is constant. (hence the term, constant power load.) Once you know that, you need to find a discharge curve of the battery as close as possible to that 5W load, and then take the definite integral of that curve (figure out the area under the curve) to figure out the WH capacity. That can be done by drawing lots of thin tall rectangles inside the curve and adding up all the rectangle area's. Alternatively, you can import the data into a spreadsheet and calculate the WH that way. Then just extrapulate that WH figure to the load to see how long it will be powered. WH / W = H.
Even my phone cannot accurately judge how much charge is in the battery, when the percentage falls below 10%, the percentage starts dropping like a brick wall as I use my phone, it will within a minute or so get down to 1%, but if I stop using my phone, warm it up in a hot car, and/or just leave it alone, the apparent charge will climb back up to 15% or so! Similarly in cold weather the battery percentage is lower than it should be. That is because the voltage of the battery will recover slightly when not under load, (basicly it is like if you are working hard, outputting lots of work, and you get really tired and lose strength, until you are allowed to catch your breath. Same with batteries.)
askfriends
askfriends
Answer 5 years ago
thank you very much for detailed answer.
though its not that simple to know that..(scratcing my head)
-max-
-max-
Answer 5 years ago
Here is a great video on the topic, I think it will help you understand a little better!
rickharris
rickharris
5 years ago
1. Your battery is only 3.7 volts ( a single Lipo cell)
2. 3.7 x 2.6= 9.62 watts - So in principle 2 hours HOWEVER I have a 3 watt LED hand torch using this battery and only get 1/2 an hour of useful life from it (so much for theory)
askfriends
askfriends
Answer 5 years ago
how did you calculate 2 hours from 9.62 watts?
sorry for noob questions.
rickharris
rickharris
Answer 5 years ago
9.62 is almost 10 watts
LED used 5 watts of electricty 10/5=2 hours of usage
Unfortunately this isn't an absolute reality because the battery can not be drained fully or it won't recharge.
http://www.batterystuff.com/kb/articles/battery-ar...
Reality will be between 1/2 and 1 hour.
askfriends
askfriends
Answer 5 years ago
yea thanks for simplifying..stupid me...
steveastrouk
steveastrouk
Answer 5 years ago
Theory is right. Battery is rated at its 10 Hour discharge rate, capacity declines as a function of the rate of discharge.
Tanstafl and all that.
rickharris
rickharris
Answer 5 years ago
:-) Must re-read Stranger... again.
