1724Views9Replies
Author Options:
how much fuel does a 250cc engine consume per minute? Answered
Tags:engines
frollard
Best Answer 8 years ago
***WARNING***
LOTS and LOTS of assumptions in these calculations, but I figure pretty close.
250cc engines at 3600rpm put out what I found on the net to be about 7-8hp.
on the high side, say 10hp
10hp is about 7500 watts.
A watt is a joule-second.
that's 7500 joules/second, or 450kJ/minute
Wikipedia says:
"Gasoline contains about 35 MJ/L (9.7 kW·h/L)"
and
"most engines retain an average efficiency of about 18%-20%"
so to output 450kJ/minute the engine has to consume about 2.25MJ of gasoline/minute (wastes 1.8MJ/minute as heat)
Gasoline @ 35MJ/L and engine consumes 2.25MJ/m =
35/2.25 = 15.6 minutes/liter or 0.0643 Liters per minute.
lemonie
8 years ago
At what RPM?
With what fuel?
What type of engine?
L
lohithglemonie
Answer 8 years ago
at RPM of 4000 and the fuel is diesel and it is a four stroke engine
lemonielohithg
Answer 8 years ago
If it's a specific engine could you name it?
What I should have thought to ask is "what output horepower?" See, 4000 RPM on "engine only" won't consume the same amount of fuel as 4000 RPM at full load in "drive".
L
lohithglemonie
Answer 8 years ago
I am not willing to know the fuel consumption of a specified engine but the average consumption of diesel per minute.
lemonielohithg
Answer 7 years ago
You got a good answer from Frollard, I hope that's done for you there.
L
Burf
8 years ago
Not enough information:
Two stroke or four?
3.5 HP work duty engine or 45 HP motocross screamer?
Constant load or variable power output?
Fuel type?
rickharris
8 years ago
So much depends. This isn't really possible to answer.
Look up some motor bike fuel figures.
