132Views6Replies
Author Options:
My arduino's L led or pin 13 led doesnt blink and my computer (windows 7) is not even recognizing it. Answered
i need to submit it this month . i am using it for a bipedal robot.can anybody recommend me troubleshooting steps.it was working well before and the cable also works.
robobot3112rickharris
Answer 5 years ago
thanks but i would like to know the terminals to attach on a board. i mean like the ones which have places for attaching motors and no need for soldering
rickharrisrobobot3112
Answer 5 years ago
Need much more detail - No data sheet for your board? or are you making one?
robobot3112
5 years ago
this sort of motor driver board in the below picture
Answer 5 years ago
The link I gave you and a little thought would have answered your question for you
The attached pic shows what I think is correct as marked on the PCB.
You still going to need to read through the information in the link to understand how it works.
Answer 5 years ago
i need the connection to the motor drivers voltage pins because i have a robotic kit on which only those connections are not included so i would only like to know the power supply . the link which you gave me was very informative about the driver and also the schematic based on it but i only need to know through which pin on the arduino should i supply it power.
steveastrouk
5 years ago
still don't understand. Were there no instructions?
robobot3112steveastrouk
Answer 5 years ago
no instructions on that motor driver. i will explain it to you . it says that the 2 voltage pins are those that you see the first ones ahead of the board and the other ones you can see by magnifying the picture.
steveastroukrobobot3112
Answer 5 years ago
Do you want to run two motors bi-directional, or 4 one way ?
steveastrouk
5 years ago
WHICH of the dozens of boards out there are you talking about ? Your question isn't sufficient to answer it. Rick rightly pointed you at HOW to wire a 293.
