580Views6Replies
how to avoid ground loop when use one powersupply for multi guitar pedal?
Hello .
I going to buid a guitar pedal witch have 2 boards in a box and use a power supply to power both of them.But i dont know how to wire them to avoid groound loop problem.Normal i will do like the picture below .Do i need to cut any wire to avoid the noise ??
Thanks for advance!
sorry for may bad English!
Best Answer 9 years ago
How far apart are the units ?
Answer 9 years ago
very close , around 2cm
Answer 9 years ago
Bring all the 0V lines to one point on the case then ground that point. Note the difference between "ground" and 0V
Answer 9 years ago
Thanks, i will try it .
9 years ago
Do you MEAN ground, or OV
9 years ago
To help pad the 2 boards so a ground loop won't be created you could use a 600:600 ohm transformer. This allows the signal to pass from one board to the other without the grounds physically touching and creating the ground loop.
