91Views7Replies
Author Options:
how to bend a bubble? Answered
I got this Brita water filtration system and it came with a plastic storage unit to keep it inside the box correctly.How would i bend this into a small airtight bubble about 1 1/2"in. high and around 2 1/2'ft in diameter,please help!?
rickharris
8 years ago
no idea what you are wanting to do more information needed
kolf3500rickharris
Answer 8 years ago
I need it for science class,I want to make an airtight bubble to go underwater and actually sustain life.the oxygen would get to the bubble which would be on metal rowels glued to the bottom of the tank,any way the oxygen would get to the bubble with a tube system.basically the whole thing would be one big tunnel.as for what shape it is,I'd like it tobe pretty much half of a tennis ball.
rickharriskolf3500
Answer 8 years ago
For the life of me I can't see how we should know that from the original question. However your best - and perhaps only bet - is to do something like this.
and here
Otherwise a bubble of air free under water will form a ... bubble....
The only other option employed by the animal world is by certain spiders who entrap air in tiny hairs on their body BUT their O2 demand is very low.
rickharris
8 years ago
Assuming Steve is right and that the packaging is a thermo plastic you could heat it up in an oven to about 130 deg C and then inflate it with an air compressor until it is the right size.
steveastrouk
8 years ago
I suspect this "bend" in the same, weird sense of hacking circuits: so the OP wants to be able to form a bubble from waste packaging.
lemonie
8 years ago
What is this, what are you trying to do with it - pictures?
L
Kiteman
8 years ago
We need a photo of what you've got, and a sketch of what you want.
