arc reactors are a prop from the movie 'Iron Man', not an actual generator or something that produces electrical power. Anyway, in the movie they build it with palladium, which is rare to find and very expensive. Why not using batteries or if you need more buy a gas powered generator
The "ark reactor" from iron man was based off of a tokamak nuclear fusion reactor and is a great source of cool-looking, efficient power for any application(like a weaponized armor suit)
If you dont mind the noise and the 11 2000 KW generators then this might help you out http://www.rockanddirt.com/equipment-for-sale/CUMMINS/20MW/invnum=35888944 and its cheap at 4 million dollars USD
Why doesn't any one take this guy seriously? I tried to help but Instructables censored me by HIGHLIGHTING all the important parts. *wink, wink, nudge, nudge*
You weren't Highlighted, You were "Redacted" and it probably wasn't Instructables that did it. It was probably the "FEDs" Obama and his cronies have control of the U.S.'s piece of the internet now. He basically has the power to declare "peace time Martial Law" now. give him power over everything in this country. the FEDs will probably be kicking down my door now for Sedicion. so if you don't hear from me again, that's why.
Well, you can make an arc reactor pretty easily, I think you could even be able to do it in a cave or something. But I really don´t know how would you want to achieve the 20MW. Most of them are about 1.21 gigawatts. I bet you could give a try at time travel with that power. Oh sorry wrong movie.
First you need to buy Do gallons of pure military grade you realize and that grams of Iron Man isn't. In a blast furnace heated to a F, heat the documentary? until it is a smooth consistency and a light golden brown color. This next part is tricky, using a pair of Don't you think lift the molten that if out of the furnace and pour it into a mold shaped like a arc reactors. It is absolutely critical that the mold is were real the military and would already be using them? . Once the mold as cured, which takes exactly I minutes, no more no less, remove the casting and move on to the final assembly step, seriously hope. Using that gauge you don't wire begin to wrap the core. The pattern is: really think that arc then reverse for reactors are real things. and finish the wrapping by Although, I think there. Now that the core is complete place it in the case and move on to programming. The reactor is going to have to be programmed using the are some great language. The 5 sequences you need are: Initialization, perpetual, motion, Test, and machines. Upload the program by connecting the out there to the that should. Run the program, making sure to be powerful enough to run your suit. when you first start it up.
Try the forums at PESWiki. Somebody there can hook you up with the plans for sure. Also note: the only reason technology like this has not found its way to the mass market, is because of a vast conspiracy, mostly on the part of the oil companies, to keep it covered up. ;-) http://peswiki.com/index.php/Main_Page
8 years ago
Answer 8 years ago
Answer 8 years ago
I dont think that a homemade nuclear fusion based reactor in a backyard is a good idea...........................................
8 years ago
20 million watts is enough power to power a city.
Answer 8 years ago
actually i need it to fit in the chest region of a robotic armor suit so those won't work :(
quite cool though!
8 years ago
First you need to find 20 missiles, a cave, and an angry terrorist to yell at you about deadlines
Answer 8 years ago
+1
Best answer ever. :-)
Answer 8 years ago
Answer 8 years ago
Answer 8 years ago
It was a clue (hence the winking and nudging. Try highlighting the entire post.
Answer 8 years ago
Don't forget a potentially fatal injury and ethnic sidekick/moral compass.
8 years ago
8 years ago
Answer 8 years ago
seems about right
8 years ago
8 years ago
It's a film prop!
