108Views7Replies
how to build dc electromagnet which produce 5mT of flux density?
which type of core should be used.it is used in electronic circuit just to wake up data logger
4 years ago
If the cylinder is not made of iron then you have the beginning of a solenoid.
If it is iron then you may have a lifting magnet or inductor.
I found this formula on the web.
Force exerted = (NI)^2 x 2Pi x 10^7 x Area/g^2
(NI)^2 = number of Turns * Current Squared.
Pi = 3.14159
Area = area of Coil
g^2 = distance to object Squared
Answer 4 years ago
You need to click the pics to see the whole image.
Answer 4 years ago
electromagnet is used to wake up logger .it uses 3.6v step input.
Answer 4 years ago
is logger a person ??
Answer 4 years ago
it is data logger.device used to read data like temperature and humidity etc.we just need to initiate the logger by giving a step input of 3.6v dc .field generated by the electromagnet will be sensed by the some electronic switch and it will turn on the data logger
4 years ago
Over what area ? To what precision ? 5mT over a soccer field is very hard. 5mT in a tube like a pencil is not. 0.01% variation is hard, 10% is not.
Answer 4 years ago
over an iron core solenoid of 2 inch height and 0.5 inch dia.
