10634Views4Replies
Author Options:
how to calculate pvc size (example 1/2", 1/4", 3/4")with diameter of it ? Answered
Gorfram
Gorfram
Answer 11 years ago
To help you use Re-design's chart, your pipe is probably "Schedule 40" - the first table shown. It wouldn't be the "Schedule 80" pipe in the second table unless thick-walled pipe is needed for some heavy-duty application.
Willard2.0
Willard2.0
11 years ago
Do you mean using the circumference (distance around the pipe) to calculate diameter? If so, then here is a conversion table.
happywatt
happywatt
11 years ago
All pvc piping is measured on the inside diameter (ID). That is copper, pvc, abs, cast iron, etc. Anything used for plumbing. If you're looking for something that uses the outside diameter (OD), look to refrigeration tubing, that is measured by the OD
