63Views3Replies
Author Options:
how to control a dc motor by taking the user input? Answered
I am trying to write a code to control a DC motor with the user input. The motor needs to stop after N iterations where N is given by the user. Each iteration doesn't have a specific time hence I used an IR sensor. The motor must rotate until the IR value is high and in N iterations the IR value becomes N times low. I hope you understand my question. Please help me with the code.
iceng
iceng
5 years ago
Set up a counter that adds each IR iteration Using the interrupt structure ma work better then polling the sensor.
Then keep comparing the stored N value to the counter and branch when equal.
VinodhT
VinodhT
Answer 5 years ago
thank you for your suggestion but I have already tried that using for loop and while loop, the motor stops only after certain time rather than after N iterations. Can you please suggest with the code.
steveastrouk
steveastrouk
Answer 5 years ago
Then you need to improve your code. Show us what you have tried.
