341Views6Replies
Author Options:
how to design and build a solar power monitoring system? Answered
Budget less than USD100, require a small solar panel(<100W will do), thin film type solar panel, need some voltage and current sensors, data acquistion card (which type of card shd i choose?)
i will need to monitor its output voltage, current and power, how should i start?
steveastrouk
steveastrouk
11 years ago
Buy yourself a USB data aquisition card and plug it into your PC.
Steve
project_stress
project_stress
Answer 11 years ago
Wow. i saw those usb card, yes, it's within my budget, but another thing is, does these cards support any programs?
For example, i will be using Labview  to plot the signals, is these card compatible with labview program?
meanwhile i will shop around, tks for you guys advice, have a nice day,
Keep the comments coming, learning grows with the day ;)
Cheers
steveastrouk
steveastrouk
Answer 11 years ago
Depends. Measurement Computing ones do. MyPCLab can output ascii over its serial port, so LabView can read it by some manipulation.  The Velleman kit ? No, again, write a quick interface between.
Steve
NachoMahma
NachoMahma
11 years ago
.  steveastrouk's USB data acq card is an excellent idea. A PCI card _might_ be a better choice. You can also get stand-alone data acq boxes with memory, but those may be outside of your budget - do some shopping.
.  Only two inputs will be needed: E and I. P can be computed (I * E). IMNSHO, some kind of ambient light strength measurement would be nice.
.  Most data acq equipment uses a small voltage or small current input signal. Many cards will accept both. Voltage levels are commonly in the 0-1,0-5,0-10VDC range and 0-20mA (4-20mA) is pretty common for current. Many other ranges are available - do some shopping.
project_stress
project_stress
Answer 11 years ago
Can i check with you, IMNSHO means In My Not So Humble Opinion ?
I will shop around meanwhile, when in doubts will ask, tks btw,
Cheers
