769Views3Replies
Author Options:
how to generate a signal (pulse) with c# using usb port Answered
for my application , I need to generate a signal wich contains 2 pulses , 1 of 150 ms and the other of 427 ms , seperated with a duration of X ms , using the usb port of my computer and c#
Tags:c
Josehf Murchison
5 years ago
We can help you better if you tell us why such as a USB Morse code transmitter which you can download the code off the net.
steveastrouk
5 years ago
You need an interface to the USB port, I don't think you can bit-bang the port pins. Try and find the FTDI FT232R chip - bitbanging that is fairly simple. Your bigger problem is this is a hard real-time problem, and system latency might stop you doing it.
