107Views3Replies
Author Options:
how to hook up xbox using ethernet cord on dial up internet ha? Answered
i have a laptop with a virgin m
obile broadband 2 go. want to hook up my xbox to it
Tags:xbox
steveastrouk
8 years ago
Get a crossover cable, plug it in, dial up and you should be good.
orksecuritysteveastrouk
Answer 8 years ago
So that's the default in recent versions of Windows? Good to know...
orksecurity
8 years ago
If your PC has an Ethernet port, it is usually possible to configure it to "pass through" the network connection from one connection (the dialer in this case) to another (the network port).
Then all you need is a loopback Ethernet cable, or two cables and a cheap hub.
I'll leave it to someone else to post the details of doing this with Windows; just wanted to tell you that you can probably make it work. However, performance is likely to be miserable.
