1873Views4Replies
how to increase i/o pins in arduino
i am working with an ethernet shield project. i need more i/o pins for my project. My need may increase upto 1000s too.
using one ethernet shield connected to a single arduino board has only 14 io pins. using MUX will not be use ful for my project.
Please help me with solution for this.
8 years ago
Depending on the requirements of the outputs, using shift registers could work, especially when used with a multiplexer, although data rates would be very low compared to regular I/O pins.
Have a look at some of the larger or more complex LED cubes, as they manage to apply PWM to hundreds of individual LEDs from a microcontroller.
What are you trying to connect to that would require that many I/O pins?
Answer 8 years ago
i am connecting home appliances with it.
So each applicance has to be controlled individually and some times in group.
while controlling individually MUX couldnt be a better one. so i need many I/O pins which has to control every individual appliances seperately.
Is it possible to connect single Ethernet Shiled with many Arduino Boards. so that i can get many I/O pins?
8 years ago
Your no engineer, consider the current load on a circuit if that many
i/o are active.
Look at distributed uP applications as a first exercise for something
better then Brute force...
A
8 years ago
Look at chips like Maxim's MAX7301 I/O expander - very versatile, easy to use, and cascadable.
