6528Views7Replies
Author Options:
how to increase rpm of 3v dc motor for making airplane? Answered
Tags:www
Re-design
Re-design
Best Answer 9 years ago
If you want the plane to go faster find the max. rpm point of the motor. Then vary the pitch of the prop. A steeper pitch will go faster if the motor can pull it. A shallower prop will give more power to climb but top speed may be too low. There are charts with guidelines available on electric r/c sites that will help you figure out the best prop size and pitch.
SGatz
SGatz
3 years ago
Would a DC boost converter work???
dchowdhury
dchowdhury
7 years ago
Buy an out runner brushless motor to make an airplane.. mor you can find brushless motor in your DVD/rw it's also light and powerfull
LiquidLightning
LiquidLightning
9 years ago
Up the voltage, and as orksecurity said you run the risk of burning it out, or buy a new one from somewhere. I've seen motors at radioshack that run 20,000 RPM's at 1.5v.
lemonie
lemonie
9 years ago
You probably need more power. while you could up the voltage, another motor would be better (as other comments)
L
rickharris
rickharris
9 years ago
I would buy a motor intended for this purpose. Usually a brushless motor running at 7 volts or so.
orksecurity
orksecurity
9 years ago
Give it more voltage (which may risk burning it out), or use a gear train or belt-and-pulley system as a transmission (but what you gain in speed you will lose in torque, so this may not be a net improvement).
Or get a different motor.
