1161Views9Replies
Author Options:
how to limit dc current at 80A? Answered
Dear Sir,
              I have a 48V 100Ah Lead Acid battery pack from which I have to power a electric drive train. I want to limit the current drawn from the battery to 80A & also short-circuit protection feature. Ipreferred MCB for this purpose but it  dint work out well. So I need an alternative for MCB, on searching over the internet I found that DC current limiter may do the job in my condition &. I am newbie in this field. Please guide me through the circuitry which may help me out.
Best Regards,
Rohit Patel.
iceng
3 years ago
What is an MCB going to do at 80A. The word miniature is diametrically opposed to your 3.8 KW (48V x 80A) control....!!! Try a 200 Volt 400 Amp MOSFET driven by a current sensing Op-Amp using a fan cooled heatsink.
Wired_Misticeng
Answer 3 years ago
Does such a Mythical Mosfet Exist?
If you have a link handy, without digging around google, that sounds like a Awesome peice of hardware !
Wired_Misticeng
Answer 3 years ago
Awesome !
Totally need to buy a pair of those to screw around with :D
On that note if you can source these (or something similar) That sounds like the way to go !
icengWired_Mist
Answer 3 years ago
They are amazing and scary, I used to make a three phase H-bridge six devices to turn an IC engine using an inverted pm 400 amp starter motor / generator.
Now the ac unit would be placed in a rear wheel well and this ac machine was an extra inch between the transmission bell housing and getting rid of the front belt system streamlined the car profile for a whole new vehicle shape.
Downunder35m
3 years ago
For the current limiting you can try some heating elements in parallel to get down to the 0.6 Ohm resistance.
For the protection check the so called "Fusable Links" in wrecked cars.
They are rated from 24 to 60V depending on manufacturer and car model.
Everythin aboue 24V max rating should work fine, the 12V ones won't stand the rated current for long on 48V.
Wired_Mist
3 years ago
You will need a pre-made electric car controller. Even something for an electric Bike won't handle that much current !
Check out a DIY solution though !
After that a simple fuse works, otherwise you may be able to find a DC circut breaker too !
FarmerKJS
3 years ago
A fuse would protect your system from over load.
I do not know how you would limit the current though
