4124Views13Replies
how to make a hybrid go kart ( i.e., with the motor and the engine)..?
I want the go kart to start with the motor and after it reaches 20-30 speed, it should run with the engine.. can anybody help..? How the transmission will take place..?
5 months ago
A go kart is typically a simply low budget setup with a centrifugal clutch and a live axle. I would put two sprockets on the axle, one for the electric and one for gas engine. Now the electric motor can be switch on manually as needed with a controller and throttle. A electric motor will produce electricity when it turns not under power, but I do not think it will charge the battery with enough amps. Maybe you could rig a riding lawn mower 12 volt alternator to be run by the gas engine to supply power but that will not help the 48 volt power supply that you are using.
6 years ago
We don't know where you live India, UK, USA ?
A wood base can do 20mph on a street but you need metal to go "off road"
Do you weld or know someone who does ?
There is no transmission just a centrifugal clutch and simple belt pulls to engage the motors.
Do you know how heavy the battery is ?
Hybrid ? Is it your intention to use a generator to recharge the battery ?
What is your budget ?
Reply 2 years ago
A group I am working with for a senior project is attempting to make a hybrid go-kart.
We plan to use a metal frame (we know someone who can help weld). We are looking to use an electric motor to start the kart and accelerate until it reaches an optimal speed for the engine to run efficiently, and switch to the engine.
My group and I are unsure of how to approach this, and would greatly appreciate some assistance in the process.
Thank You!
P.S. We are in the US
Answer 6 years ago
Thank You for the reply..
I live in india
yeah i can weld and also know some friends who can..
the battery which i want to use is 48v dc (4 batteries of 12v each) and it should be very light in weight..
Are there any other source for charging the battery..? if yes, the what is it..? but if no, then i should go by the generator..
and also if you can give some new ideas or innovation, it would be great..
Answer 6 years ago
It is not clear to me if you want to start on electric and run on the IC engine, or the other way around.
Good you can weld. https://www.instructables.com/id/Electric-Go-Kart-F...
An alternator is the better generator to work with.
Answer 6 years ago
I mean to say that.., for first 20-30 speed, the go kart should run with the battery and on the same time after it reaches that speed, engine should start and run..
It should run simultaneously (with battery and engine)
The reason i want to use the battery is for the faster startup and pickup..
Answer 6 years ago
IC = Internal Combustion engine
So, when both the electric motor and the IC engine are running.
is the IC charging the battery and turning a different wheel ?
Answer 6 years ago
Can you explain me how the IC will charge the battery..?
And i am planning to keep the motor..
Answer 6 years ago
A portion of the IC mechanical shaft torque will use a belt and pulley to spin an alternator that generates suitable electric energy to charge the battery.
You understand that you are planning to build much more then a go kart
You are actually trying to building a car on a Zero Rupee budget.
My best advise is to go to university and study engineering to realize how to mechanical and electric components need to be assembled to make a real go_kart and understand the difference between a car.
I will strive to answer your questions but you must make the decisions.
Now ..... Is it your plan to :
1. Power the kart drive wheel only by the electric motor ?
2. Power the kart drive wheel by the emotor then switch to the IC separately ?
3. Power the kart drive wheel by the emotor and the IC together ?
4. Power one kart drive wheel by the emotor and second drive wheel by the IC ?
5. Or do you have another way ? Please explain !
Answer 6 years ago
okay listen.., i want to make a hybrid go kart so please explain me the DRIVE TRAIN..
Answer 6 years ago
I hear you....
Are you ..... able to read ..... and DECIDE which hybrid go kart variation 1 or 2 or 3 or 4 you want to attempt to make.
Maybe then I could try to arrange some kind of drive train.
IF you do not understand 1234 you will not understand the answer you seek !
6 years ago
1. such a vehicle may be illegal on the road
2. WHY?
3. most hybrids are very complex - the electric motor drives through the common gear box. this will be very difficult to arrange DIY.
Answer 6 years ago
It is not illegal
