1104Views3Replies
Author Options:
how to make auto headlamp light brighter without to replace with a new unit.? Answered
My car headlight is getting dimmer and dimmer because the reflector in the headlamp had worn out, is there any low cost way that i can refurbish the headlamp to make it light brighter without to replace it with a new headlamp unit.
Tags:car
cheesehead
9 years ago
the problem is if you supply ur lamp with more wattage than it is rated for then you will burn through lamps with much greater frequency. have you thought about adding some white leds? that would probably be your cheapest and easiest (relatively permanent ) fix. without changing the lamp housing... good luck.
lemonie
10 years ago
Try lining the reflector with aluminium foil if that's the bit that is defective? L
CrawdadMan
10 years ago
You could defog your headlights covers. Search it on instructables and if nothing comes up look on google
