236Views2Replies
Author Options:
how to make magnetic and fluid resistance based exercise cycle? Answered
make a stationary exercise cycle with fine control on resistance to rotation
Re-design
Re-design
11 years ago
link the pedals of a bike on a stand to a car alternator of a generator. Put a very heavy duty variable resistance load across that generator/alt. It will need a heat sink. As you make the load higher the resistance will get higher. For $75 you can buy a unit to set your bike in that will do exactly that. If you want to go hydro. Connect your bike to a washing machine pump or something similar. make a looped system where the pump is continually circulating your liquid. Place a valve in the system that you can easily adjust and that will make the force easy or difficult.
frollard
frollard
Answer 11 years ago
I second the fluid resistance...unless you truly need a heater for the winter :D I wonder if a pressure washer pump could offer enough resistance at the required rpm. other style impeller pumps would probably be better (as you suggest dishwasher)...
