6428Views9Replies
Author Options:
how to make paper hydrophobic and waterproof? Answered
I want to make a vase of paper, by the principle of the paper beads. My question is: how can i made the vase hydrophobic and waterproof?
rickharris
rickharris
10 years ago
You can buy waxed paper you know in most cook shops.
7654321
7654321
10 years ago
Read here
* 1
You will need 6 ounces of alum, 1 ounce of grated castile soap, 1 quart of water and 3 ¾ ounces of beeswax. Alum can be found in a grocery store spice aisle. Beeswax can be found online and at health food stores.
* 2
Place 1 quart of water in a pot on the stove over a medium heat. Add 6 ounces of alum and 1 ounce of castile soap.
* 3
Bring the mixture to a boil. Stir continuously to dissolve the alum and castile soap.
* 4
Add 3 ¾ ounces of beeswax and melt it into the boiling water. Continue to stir continuously.
* 5
Once the beeswax has melted in, remove the pot from the heat.
* 6
Pour the solution into a pan or container large enough to fit the paper you want to make waterproof.
* 7
One sheet at a time, place the paper into the solution. Use tongs because this mixture will be hot. Handle carefully.
* 8
Remove the paper immediately after it has been submerged, do not leave it in the solution to soak. Place it on wax paper to dry.
steveastrouk
steveastrouk
10 years ago
Steep it in molten wax ?
Spray thoroughly with a polyurethane varnish ?
Steve
lemonie
lemonie
Answer 10 years ago
+Steep it in molten wax
L
Re-design
Re-design
Answer 10 years ago
I like the varnish idea best.
oldmanbeefjerky
oldmanbeefjerky
10 years ago
"hydrophobic: a dreaded fear of any bodie of water"
i cant imagin why you would want to make paper afraid of water, but if you want to make a vase out of paper, or anything really out of paper, wateproof, get yourself some polystyrene, and by weight, add 1 10th part polystyrene to either acetone, gasoline or methylated spirits.
this will make an extremely weak laquor, which will easily soak into paper, and harden to have a final strength equal to that of a plastic milk bottle!, and will be very waterproof, i use this to waterproof my smoke bombs and fuses so i can let them off underwater, and i tell you, it works.
the addition of a dense oily substance like wax, will make it more pleasant to touch, and will feel like normal smooth plastic even more. wax will dissolve in gasoline, but only a little bit, say maybe 1 5th of how much polystyrene you added, or else it will feel waxy
kelseymh
kelseymh
Answer 10 years ago
http://en.wikipedia.org/wiki/Hydrophobic
contrast with
http://en.wikipedia.org/wiki/Hydrophilic
seandogue
seandogue
10 years ago
traditionally, I think you oil it. Not sure how you keep ink from running though or what oil you would use.
